1 - 9 of 9 Posts
i got a jdm d15b and when i drive it itll drive for a little than stall. when turnin the key it just cranks. eventually after lettin it sit there for 15-20 minutes itll start back up, but will do it again if i drive long enough.when i crank it the cranks get weaker if i keep tryin to start it.it wont bump start either. has ne1 had a problem like this b4, its drivin me nuts!
when it dies if i get out and pull the negative battery terminal itll start back up again to die shortly after if that helps
fuel yes spark havent check but i just changed the coil, plugs, and wires, going to check for ne moisture or shavings in the distributor. i also just started to kick code 15(ignition output signal) so im startin to lean more towards main relay, but ne advice ill take
it was the ignitor in the distributor, when the car died i checked spark and got nothin...lookin for a new dizzy cause the icm is mad expensive...does ne1 know if i could use ne obd1 dizzy on a d15b? sum1 said no but i wasnt to sure myself
1 - 9 of 9 Posts
