I have my d16 I put high compression piston and skunk 2 intake manifold Now I’m thinking to buy a stage 3 cam it is a good idea to put a stage 3 cam with the high compression piston? The cam it’s a stage 3 turbo but I’m not going turbo
what the fuck is a stage 3?
Never finishes (TWSS)
91 Civic SI hb/ 01 GSR
Stage 3 vtechs cuz, mad poppin
One companies stage 3 is another stage 5 and so forth.
You have to know the brand and series to state a stage number.
Skunk 2 pro 2's or 3's arnt the same as the tuner 2's or 3's. But if i said stage 3, did i mean pro or tuner?. One is a mental big cam the other is mild.
Also dont use a turbo cam on an all motor car. Lol there will be next to no over lap on the valves and thats what makes power on a NA car. Better off leaving stock cam over a turbo cam id bet.
Id be ok with a turbo car running a NA cam is it would just push the power up in the rpms but not the other way or will you be pushing the power down
Discussion Starter · #5 ·
Thanks bro that help me out
