1 - 10 of 10 Posts
Aight so im bout to get some stage 2 cams .. Buh was cams without valve springs.? So i got some question about to valve springs..
How do i take them off with out droping a valve..
Do i need an air comressor.
Was the best tool for the valve spring.
Ann do you think is even worth it to put cams
Thanks in advance
( oh an i wanna do it wit the head still on the car)
Black/Green Civic HB
Your going to have to pull the head if you wanna change springs....(ie using a spring compressor)
But you can swap cams w/ o removing the head.
The bigger question is tuning!
Do some more research!
dont think its a good idea to put (cam's) in.
wrong.... you dont have to remove the head to change valve springs. they make a tool for it and you put compressed air in the cylinder so you dont drop a valve.
and no you cant swap cams you can swap 1 cam into your sohc without removing the head.
but seriously searching will give you all the answers you need on the website
I got a d16z6 an it already pulls pretty hard .. I wanna put the cams den get vitra pistions in the future wit an ebay turbo. Buh for not just "cam" lol and springs
1 - 10 of 10 Posts
