1 - 12 of 12 Posts
Honda
i dunno how well it would work because of how the inlet/outlet are offset. i mean im sure it would work, but it might make more work for fitting the piping in. Have you ever seen one to know what im talking about, i dont want to confuse you or anything
but anything is possible and im sure its been done and someone can help you more than i have
Honda
i thought the in/outlet would work better becuase they already have that 90 degree bend, but thats just my thought
well they might. they arent exactly 90 degrees though, they are a little more offset than that AND they angle upwards. but like i said, ive never done it.....it may just be the way to go., but then again it may not
FAMILY MEMBER #316
you can cut the ends off and weld new ones on. lots of companies sell the inlet/outlet piping.
I got one in my rex, wasnt to bad if you can weld alluminum, had to cut the endtanks off and extend them about 3" on each side and then re weld the outlets to face the proper direction, i got a ton of pics of it on my computer at home, ill post em um later on tonite, oh and it requires some cutting of the rad support aswell!!!
This is the only pic i have handy where you can even remotly see the intercooler!! but il put some more up when i get home tonite!!
same^^^
Hey, champ, nice work. For those of us who don't weld AL, what wold we expect to pay for someone to do this?
If you had a half radiator on your crx, did the turbo-side intercooler inlet clear the car's sheetmetal? If so, then all that should be needed is to cut a small hole through the shetmetal on the opposite side for the intercooler outlet. I'm thinking about this intercooler now.
Also, what were the stock measurements vs. the modified measurements if you don't mind. :TU:
-josh-
Your in luck, the car is at the shop today so i will go measure for you and ill let you know later!!
Prolly if you knew someone you cold get it done for cheap but just a welding shop prolly like an hour for labour if you have all the pieces cut out and ready for assy.
1 - 12 of 12 Posts
