1 - 20 of 20 Posts
97 Civic EX
Does anyone know how to turn the SRS light off? Or know why its on in the first place? Its a 97 Civic EX. Let me know. Is there something I can fix to turn it off?
95 ex coupe
there is a way to jump with a wire.
il try to find it for ya.
95 ex coupe
Reactions: 1.5Slowmatic
Well?
that may not always work but it comes on anytime you take the battery put of the car. I know mine was on and i tired to reset it but it wouldn't so something was wrong. Than 2 weeks ago when i wrecked the bags still came out even though the light was on
endo_bobo
1998 Civic Sedan
You could always take out the SRS LED if you want to go that route.
95 ex coupe
mine is on from unpluging the airbad.
changed the steering column cause the ignition went out.
tried resetting it like the link i posted. went off but came back on so something is wrong with mine. horn and cruise doesnt work and thats all tied in with the airbag wiring
97 Civic EX
well thanks for all your help guys
most likely if your horn and cruise dont work and the srs light is on (wont reset) its due to your srs clock spring being broken.
97 Civic EX
horn and cruise work fine. one of the reasons i havent put a new steering wheel on it.
97 Civic EX
i didnt think about the plug under the seats, im pretty sure its not connected. that would cause the light to come on?
endo_bobo
1998 Civic Sedan
I don't think so, mine wasn't plugged in since I got my car and my light only came on after I changed my steering wheel. But it wouldn't hurt to check.
97 Civic EX
appreciate the help, ill check it and let yall know.
97 Civic EX
Discussion Starter #16
where can i get a fuse diagram, i got the car without the cover.
huh?
Did you make sure the plug is not damaged behind your gauge's? If you messed up a pin while plugging it in, im sure it could give you problem..
take it to a shop and have the code cleared. I cleared the code on my EK and it has not came back since. A buddy did the same thing on his EK or BMW. Very common for codes to throw, clear them and it never comes back. something could have been unpluged, etc.
1 - 20 of 20 Posts
