1 - 3 of 3 Posts
Well my search for reseting the srs light doesn't seem to be the issue because my light doesn't stay on a ll the time.
Just every so often probably like 6 times on a 15 ride to work my srs light will turn on for about 4 seconds then shut off, it seems to be at random sometimes within a minute of each other sometimes 5 or 10 min apart. When the srs light turns on it seems to be pulsating the power thought the car meaning my headlights, dashlights, anything lit up bogs down like I was powering 4000w or something of bass.
Any ideas? Thanks.
Automatic 1999 2dr Ex
Have you charging system checked out. Also check the ground junction (C116) under the intake manifold, it likes to rub on the bracket and short out. That usually causes a crank no start thou but never know
Have my charging system checked out as in my alternator? And I will Google that junction to see where abouts it. Thank you for the reply.
1 - 3 of 3 Posts
