1 - 19 of 19 Posts
93 maybe 94 coupe
Ok, so the car hasn't been ours long and hadn't been maintained as well as my car.
It developed an rpm variable noise which I figured to be bearings on the 200 amp alternator previous owner had installed for a 10k stereo system. It was gorilla gripped in there like only a juiced up meathead could have accomplished. That belt could have cut steel it was so tight. The lower mount bolt took 36 inches of breaker bar to pop loose so I didn't even diagnose it, I just replaced it.
Noise continued and slightly worsened over 3-4 days of use, stopped getting worse.
Next day PS reservoir was smoking when I checked for fluid, so again, fixed the "no brain" solution w an extra pump we had lying around and noise was gone for like 2 minutes.
Til the belt squealed. Tightened it slightly and cleaned it, original noise returns.
Pop both ps and alt belt, noise continues.
Reinstall both belts condemning myself for failure, complete silence.
Next time I start the car original noise returns, quiets itself as we drive 15 miles. By the time we get out to the farm it's almost silent. So warming up had an effect.
Jessie complained a belt squealed, and I had spilled some ps fluid on it the day before so i cleaned + tensioned both belts properly and again complete silence. For 2 days.
Jessica complained the belt was squealing constantly now but the original noise was gone. I went and started the car, no belt noise. No original noise.
Took it for a quick drive and there was a much quieter, variable with rpm squeal nearly constantly. Then silence. Then the noise returned and there was an unnerving 2 seconds of a grinding noise, followed by the sound of water flushing from the passenger side dash. I nearly soiled myself.
Drove home about 2 miles, didn't overheat, didn't lose much if any water....
Now I'm afraid to let her and the kids go anywhere in it.
Planning to start it up, inspect things and see what noises it's making now, after checking water level so as it warms up I can watch for leaks and loss as (hopefully) replies to this pile in.
Note, I'm not sure what's up w the water rushing sound in the interior... not the first time it's done that and my car never does it... heat works properly in both cars.
Thoughts?
93 maybe 94 coupe
This morning, complete silence til it warmed up. Sounds like crickets at idle, the squeak of a rusty hinge but more high pitched, or turning a glass stopper in a bottle or... crickets. Then with revs it increases in frequency to a constant squeak noise that is continuous.
Full of water, no leaks visible outside lower cover with no drips on the ground.
Tired of throwing parts at it. Bout to throw water pump and tensioner at it though. Car needs to be family friendly by Friday night.
Edit: sorry for double post, I just NOW stumbled over how to edit in the enhanced mobile view.
The original LOUD grinding/whirring noise is completely gone. Just these crickets left to iron out.
does the car have a/c? could be idler pulley for the timing belt. how does the timing belt look? how bout the crank pulley sprockets?
93 maybe 94 coupe
Ouch. Cover is coming off as we speak, bout to make a parts run. Getting Gates timing belt kit. Is it normal for the timing belt to look like it's been getting wire brushed? Tread side looks new
Oh and no ac
93 maybe 94 coupe
So far so good. Spent most of the afternoon being a dad so I ran out of light. It's torn down, probably should go pop the pump seal so it can drain out overnight, I'm no earth hater it's just water wetter and h2o
Kinda sucked I had to buy the same tools, again....
93 maybe 94 coupe
Tensioner was siezed
Good catch, and be happy you pay enough attention to your vehicles that no one was stuck on the side of the road.
a seized tensioner is kinda rare, but a given with enough age.
that car might have been a candidate for just a belt swap at some point in its life, and perhaps tensioner was original or from first T-belt change
93 maybe 94 coupe
Said made in japan, everything else was non oem. It's rare they seize? What about ebay ones?
Yeah I was really surprised it wouldn't move at ALL, explains the brushed looking belt back though I'd say.
And thanks. Most of the time ppl see the hondas and assume I like to run stuff into the ground. I try to keep on top of it so i can justify upgrades
Ive put well over 100k on an ebay timing kit before.
the tensioner was never seized, but the bearings had certainly seen better days when it was finally changed.
Ive never had one seize. Ive simply had the cheap ones come close to coming apart lol
OEM ones?^^
I wouldnt any tensioner past 200k miles, regardless of branding.
my luck has never been that good :1eye:
93 maybe 94 coupe
Discussion Starter #16
Am I supposed to fill the block with water before it'll pull water? I ran it for about 4-5 minutes and it's not doing squat. Heater won't blow even mildly warm, lower hose cold, radiator level unchanged. Must have a hell of an air bubble in there but aside from filling from the upper hose idk how to get water to the pump.
I just hope I didn't kill my new pump or get my head too hot. Waiting til it's bone cold again to do anything.
93 maybe 94 coupe
Discussion Starter #18 (Edited)
So I hear and am now doing, but the upper hose had water in it. I disconnected from the radiator and forced water into the head but as I did so the radiator overflowed w no bubbles.
Is it safe to run the car like this to attempt bleeding? I have no indication circulation is happening at all and the bleed valve indicates no pressure. Unless I squeeze the tube. Then some shoots out the bleeder.
And now it is too low on gas to start on stilts, lowered it a bit started up, held it at 2500 for a few seconds and then it idled rough so it's either losing gas or getting really hot internally.
I'd run down to grab gas if I knew I wasn't causing damage. It's just long enough that the car should warm all the way up by my return.
Temp gauge solid cold, moves very slightly up and down, has previously been reliable
93 maybe 94 coupe
Discussion Starter #19
Poured in some gas, jacked the passenger front sky high, problem solved.
1 - 19 of 19 Posts
