1 - 7 of 7 Posts
CRX ECODiesel Ram
if your AFR is where it should be then why worry about something that does not seem to be showing a problem?
I was under the impression that the fuel curves should be smooth.
I did smooth out the curves on the 2D map and the car ran rich so I'm going to go back to what worked unless anyone has feedback
That's sloppy of your tuner. It is not the end of the world, but, if you want to change things up, then you are going to have to completely retune that area of the map.
I'm the one tuning it. I'm learning so it's my own fault.
So if the AF is right on what's causing the spikes and lines crossing and how would I fix it.
1 - 7 of 7 Posts
