1 - 12 of 12 Posts
B
I have and 88 honda civic DX with a Z6 swap and a 91Si tranny. I was passing a stalled car and looked down after a few miles and speedo read 0.
After the swap the speedo needle would bounce up and down afew MPH. I was never really worried about this but now it doesn't work at all.
I checked the cable where it goes in the trans and it seems to be in there all the way. Theres a cotter pin or something an inch or so above where the cable goes into the trans. Hope this is enough info
the cel you would get is the vss sensor. so if you dont have a cel then the cable and or vss is ok. maybe the speedo?
00' Honda Civic EX
ok i am having the same porblem but my chluch was just replaced and then it stoped working so if u can tell me anything that would be cool
What year Ford you driving?
try getting a friend to help you let the car roll a little bit while you are pushing the vss cable in make sure its in the whole way .. thats how i fixed mine .
well mine is doing the same thing but i have check the cble like 20 time i think it is in but when i go to drive the cable never spins but i dont know i left it oof the speedo to try and see but that did not help i have no cells but i dont know what to do now
1 - 12 of 12 Posts
