1 - 17 of 17 Posts
I have a 1993 civic with an ls swap i just got. I was curious if my speedometer is 7 mph off will this cause my trip meter to be off as well?
---i tried searching but cant find a definite answer
95 Honda Civic DX
Yes it would be off. I'm not sure how much exactly it will be. I wouldn't figure it'd be much.
Couldn't honestly tell ya, if you're off because of tire size then most likely.
Just measure it from mile marker to mile marker.
^^ This is your best bet to find out how much it is off.
1988 Honda CRX
It will be off by a percentage rather than an absolute number.
1988 Honda CRX
The way to kinda fix it is to do the relatively simple sums in your head so you learn what the indicated speed actually is. Heck even use a felt tip pen to mark important speeds on the dial.
i have the same issue, 10 Kph off on the speedo (reeds 10 higher so it makes my car look faster!!)
my trans serieal says s40 and from my research this is a LX trans from 96+ and not an SI. which have different ratios.
my 93 civic also has a 99si cluster i do have a rpm from factory and there is a blue outline around the rpms, speed, ect (hence 99 guages)
Could the fact that i have si cluster and lx trans bugger the reading or do i have all my stuff wrong here. i dont know the history of the car bought like this!!
1988 Honda CRX
Typically wrong speedo is change to tyre rolling dia. Anyway even from factory, speedos are often a fair bit off. The Honda speedo gear is driven bt the differential where it turns at wheel speed so the FD does not influence it. I can't speak for different models
If Speedo is off Odometer is off
94-4Door 96-Si
n00b Question
Is there a way to have it recalibrated? My 96EK also has it 10MPH faster, and I can only asume it's because of the bigger wheels. The EG does not have the same problem since it rolls on 15's
Civic coupe EJ6
All my cars have been about 10% off
Ford escort, VW bora and the civic.
I thought about 10% was average.
1988 Honda CRX
!0% is convenient as it makes the maths real easy to do in the head. Indicated 50 = 45 or 55 depending on which way it's out.
88 RT4WD wagon
my cable speedo is increasingly off. its a little ahead till 20. on till 40 then at 55 its showing 60 at "90" im only going like 78-79. So much fun for a passenger though. "OMG we're going 120 slow down!"
1988 Honda CRX
My cable speedo gets inaccurate by a bigger %age as it gets faster and varies from day to day, but it's done 400,000kms
My one with 200,000kms is only about 3% out.
I now just use the satnav to calibrate in my mind.
1 - 17 of 17 Posts
