Not quite sure, but I belive you where thinking about the reverse indicator...open end wrench and be careful with the sensor. i dont remember the size but i think it was a 17mm.
Yeah its about as simple as this ....reverse to install10mm socket, unplugged the connector, unbolt, twist and pull......
sorry, only one 10mm bolt....... part #10.....Yeah, just unplug it and it "should" be two 10mm bolts on each side of it.
simply the man!sorry, only one 10mm bolt....... part #10.....
