1 - 13 of 13 Posts
MyblkVTEC said:
yep, the VSS is it called??
Ya it's called the VSS.
Check if u plugged it in. Or u might need a new 1.
Honda Civic
Clutchmaster said:
should you be able to move the little metal tip in and out?I pulled the VSS out of the tranny and at the end of the rubber boot is a little metal piece and the metal can wiggle and I can pull more of the cord out of the boot
check the condition of the 3 pins in the plug...that was my problem. one broke..
D-Series Destruction Master
hey, is your car 92+? If it is, do what these guys say...but if it's 1 88-91, then they all need to shut it.
88-91's have a cable, and it sucks ass cheese. Replacing the cable will fix your problem.
If you have a 92+, then ignore me.
Administrator
Honda
My Car:
89 CRX D16A6
so, replace the cable.
1 - 13 of 13 Posts
