1 - 6 of 6 Posts
I have a freshly built d15b block with a z6 head. i have a z6 head gasket and IM. its all stock with a cold air intake. p28 ecu.
-- also have a dx tranny
I just need to know some rough specs. hp, torque, compression ratio
are they the same as a d15b vtec.
is this still true although my bottom end is not jdm?
doesnt the jdm bottom have a differant crank
OMG TOTALLY COOL TITLE!!!!
So you have a b2/b7 block not a d15b block? Hp is about same as stock give a lil for head swap and cai not much tho. And compression hit up zeal works and that will give you your answer.
yea thats what i thought the rod lengfth is also differant if i am thinking right from like 135 to 137 or something.
but with a b7 bottom and a z6 top end ,IM and ebay 4-2-1 header and 3" straight pipe and obvious cold air cold air intake i should be close to z6 specs with a bit more compression???
1 - 6 of 6 Posts
