1 - 20 of 34 Posts
i dont no much on this but what is the differnece between cheap spark plug wires and like bosch spark plug wires.. is there a point in buying exspensive ones
well i was gonna get the bosch ones but i dont know if there is really any point if the type of wires dont make a differnce and if they dont perform any better
NGK/Magnacore/MSD
choose one and be done.
ngk ftw
will putting on spark plug wires even help performance? i was told otherwise, that stock worked the same
Unless your running a race only tubo setup stock are fine. There's no gain from useing anything else in most cases, kind of like putting 100+ unleaded in a stock car.
NGK is the concensus. No, there isn't much of a power difference between sets of wires. The power differences come when you switch from old wires to new ones.
hmm so wires are "mainly" cosmetic pieces...still look bad ass, i might get me some mmhmm
you got it. New wires are better than old worn out wires, its a simple concept. Unless you are running a MASSIVELY upgraded ignition system, anything other than OE/NGK wires are a waste of money.
NGK, Spilt fire, Ultra, Nology Hotwire (if much budget)
1991 crx dx
the more expensive wires doesnt really gain any hp but it does help in reliability abit. Thats why i put msd 8.5's on mine because the regular cheap wires you by (valuecraft) i think are just cheap and the connection isnt good at all. They will want to ride up and come off of the sparkplug.
96dx saloon
really the only time you will see gains with plug wires if yours are worn out. just get stock wires. they are made by ngk.
ryan
What does those NGK wires cost in US? I could get OEM ones for around ~60EUR/~$80 here from dealer, expensive? Asked Magnecor, 125EUR for stock 8.5mm and 139EUR for custom-made for Bosch Motorsport wasted-spark coilpack (I have one), I think that's insane price for a few pieces of wire.
Aftermarket supports seems to be pretty low here on Finland on these..
1 - 20 of 34 Posts
