1 - 14 of 14 Posts
One of my spark plug wires went bad like it doesnt give a proper spark and my engine works on 3 cyl.... I borrowe one from friend for now but can you guys give me suggestion on wich ones to buy. I want something cheap but quality lol. Is APC good?
thanks
CR-Vtakin
thanks
does the thickness of the wire matter?
just buy the ngk blues. you wont have to worry about thickness. ask anyone on here and they will vouch how good of a wire they are.
CR-Vtakin
What car? If its an A6/b2/b7 Use the NGK A6 plugs as they are usually slightly cheaper than the b7 ones.
Otherwise use the z6 plug wires.
OEM or NGK Blues.
ngk blues rock! you can pull them off the dizzy and plugs a bunch of types, and I mean a bunch, and they still fit perfect and don't break. not like some wires where you pull the boot and the wire goes threw it. don't corrode. I've had a set on my car for a while, that still work great.
1 - 14 of 14 Posts
