1 - 9 of 9 Posts
I have a D16Z6 that runs NGK IRIDIUM ZFR5FIX-11 & recently got a set of NGK IRIDIUM ZFR6FIX-11 PLUGS & as I understand it they the same except for the heat range so witch one is hotter & how would you decide what temp plug to run. Hate to throw out good parts if I can use them.
08 H-D Ultra Classic
Why would you use Iridium plugs?
Does the car have a modification that calls for them?
Has the tuner suggested the car needs them?
If its bone stock use the stock copper replacement for $1 or $2 versus using $15 iridium plug that has zero gains.
Meat Popsicle
91 CRX Si
I only use iridium plugs on car that specifically call for them like the K20A2 in my RSX.
Supercharged d16a6 in the CRX gets $2 NGK BKR7E’s which work great.
Edit: looks like OP already has the plugs so here’s a NGK heat range chart:
https://www.ngk.com/learning-center/article/251/heat-range-conversion-chart
And here’s another helpful article:
https://www.ngk.com/learning-center/article/200/how-do-i-find-a-colder-or-hotter-plug
Btw I found these in less than 2 minutes by just googling “NGK heat range chart”
I have always had better luck with 88-00 civics running the factory specified spark plug, regardless of any mods, IF the stock ecu is used (as in no tune).
My 2013 Honda Fit, however, enjoyed getting colder heat range plugs that were factory on the AP1 Honda S2000. Made a minor improvement at the drag strip after a few fuel tanks worth of driving for the factory ecu to finish learning the new knock range.
Current mods: 3-2-1 header with 2 1/4" cat back, cold air intake, adjustable fuel pressure regulator (currently set about at stock spec), Magnacor spark plug wires, 8Lb flywheel & ecu chipped & dyno tuned to 127HP & 110Ft-Lbs at the wheels. Future mods: long runner intake manifold, 66mm throttle body with larger fuel injectors to match & retune ecu.
you need compression prior to any more mods.
big throttlebody is simply going to eat up your low and some midrange power, and only net a few ponies up top.
compression plus camshaft = FUN. and 150whp+ possible.
All this below is not needed....
There, I just saved you $1,000, next.
Integra DB9
There's too much bollocks talked about plugs.
Stock engine = stock plugs. The rest is money wasted.
1 - 9 of 9 Posts
