1 - 17 of 17 Posts
D15 rod = 390g
D15Z1 rod = 405g
D16 rod = 430g
D pin = 70g
LS rod = 485g
P28 piston = 235g
P29 piston = 260g
P2M piston = 220g
PM3 piston = 240g
P2P piston on rod with pin = 715g (215-220g for the piston)
bearings are 30-35g per set
I'll add other specs as I come across them.....
My scale only has 5 gram resoultion....but it'll do :)
I have a few PM3s and PM6s you can weigh to add data to your collection if you bring your scale the next time you're up this way.
have scale, will travel!
The Great Weldini
91 civic
pm7 weight the same as p29?
D-series Janitor
Front Engine Dragste
Bense 9 years ago like:
Not doing it for bense (as noted, like he cares 9 years later).
Doing it for anyone searching the internet from here on out looking for piston weights since there's nothing on the PMS piston
Same deal with the 10 year old d15b6 thread . . .
del Sol si '94
PG6b's. With and without pin (obviously). These have coated skirts, so theoretically that could add weight, I guess
1 - 17 of 17 Posts
