1 - 9 of 9 Posts
formerly Kit88
Hi guys, here are some pics of the progress on my new set up, just need some adjustments on the downpipe and need finished my ic piping on the compressor side.
is this a good place of the endyn catch can ???
formerly Kit88
the oil line feed and return are not vertical, the oil line feed is a little bit clocked to the front side, then the return line is clocked to the block, how can I fix this???
Please see at the next pict and I need to know if I loose the bolts that hold the hot side, maybe I can clock the center of the turbo ???????????
You can just loose the hot side and clock it but your compressor housing outlet will be facing a different position. So therefore you'll going to have to loose both side. And I think your catch can is fine where it is. But keep up the good work.
formerly Kit88
Thanks Bro.
1 - 9 of 9 Posts
