is there any obd0 ecu that can manage the vtec control?
if yes, is that ecu chipable
if there are OBD0 motors, there must be OBD0 ecu's, lol. Turbo-edit is the most common tuning program for OBD0 ecu's (as far as i know). I dk much about OBD0, so you should search. but if you wanted to swap in OBD1 you need a P28is there any obd0 ecu that can manage the vtec control?
TurboEDIT can make any obd0 chippable ecu a VTEC ecu with the 1wire vtec option. you have to tune for VTEC with only one set of maps but its hella cheap and it works.Yes . . . PS9 and use the converter lock-up. Turboedit has a caption for VTEC operated by the lock-up wire.
