1 - 6 of 6 Posts
S
Does the EX ecu control the shift points in an auto trans if so is there a way to increase shift points to say 7000rpm. 2nd question Do I have to install a knock sensor if so how do I do that.
R
You need KS, under the intake manifold. Easy to install, but BEFORE the intake manifold :)
S
ok cool...btw how much does a knock sensor cost new/used thanks.
Sure enough, when the head is off you'll see the empty threaded hole on teh back of the block, put the sensor in there.
If you got an automatic and auto Y8 ecu, make sure your intake manifold & t/b are both from a Y8 auto, that seems obvious. The knock sensor uses a 2-wire round plug (same as water temp, VTEC pressure, p/s pressure, manual Y8 IACV) except it just has 1 wire going into it.
Here's the link on where to hook it up. You just need a length of wire with an ecu pin on it to put in the ecu connector:
96-98 Civics
http://www.we-todd-did-racing.com/wetoddimage.wtdr/i=wMTk5NzM4NnM0MTNkZmQzMXk1NDE=
99-00 Civic
http://www.we-todd-did-racing.com/wetoddimage.wtdr/i=wMTk5NzM5NnM0MTNkZmQzMXk1NDE=
1 - 6 of 6 Posts
