1 - 2 of 2 Posts
Well im new on this and im stuck on my problem with my 91 crx d15b2 just completed mpfi swap and was running for a couple hours but sounded like it started to missfire so i pulled my wires as it was running to find witch one was my problem and pulled my number 3 witch must have been doing most of the work because it died i went to try to start it and noticed my ecu has a soild red light on and car only cranks so i grabed my backup ecu and same thing i tryed to cleaning all my ground but same thing im stuck on what to do next
if anyone has any advice please share so i can try
thank you
89 EF 4wd sedan
Was the car running fine before you did the MPFI swap?
What wires were you pulling? Best place to start is just go over the wiring you modified, confirm everything is correct to whatever how-to you're following. Feel free to post up more detail on the process you went through, it'll help give more accurate advice.
1 - 2 of 2 Posts
