1 - 9 of 9 Posts
ok my goal are 200whp, what will be a better motor to turbo and to get me to my goals
if i go with the sohc zc....
I will keep the car obd0 and tune with turbo edit, and thing will be easier and cheaper as far as converting
if i do the d15b i will covert to obd1 and tune with uberdata or crome
I have been leaning toward the zc due to it being a cheaper swap
ZC FTW, the D15B i think is a great motor but the ZC is a 1.6L. The D15B uses custom pistons which could become a problem later down the line if you decide to build the motor. while the ZC is pretty much a D16Z6 which has tons of parts here in the states at your disposal. I had to make this choice a month ago and i went with SOHC ZC Vtec (OBD1 Version)
D15B would be kinda boarder line for 200 whp but i suppose with a good tune and not driving the living piss out of it you would run it on stock internals. But the ZC deffinatly has alot more window for oppritunity for upgrading internals
Formally known as SPONSOREDCRX
sohc zc non-vtec. better to boost than a d15b vtec.
1 - 9 of 9 Posts
