1 - 3 of 3 Posts
Lifetime Awesome Member
'89 CRX HF
ok, so i know the sohc non-vtec zc is basically the same motor as the a6. but does this mean that aftermarket parts such as cams, intake manifolds, are interchangeable between the a6 and zc. i know that there is no aftermarket im for the dohc zc, but if the sohc version is the a6, then i should be able to buy an aftermarket mani made for the a6 and it will work on a zc right? same with cam?
'89 CRX HF
one more q, sorry, this is a 40 question, jump around thread. i thouhgt i just saw this on here but i cant find it. when swapping a motor/tranny, is it best to pull out and install with the motor attatched to the tranny, or should it be done seperately? just wanna know which will be easier.
1 - 3 of 3 Posts
