21 - 40 of 79 Posts
The Great Weldini
91 civic
Discussion Starter #21
Very nice I'm tempted to put these on the Crx....
How's the throttle cable and tps setup look?
You need to get a tps adapter which can found at circuithero.com
As the throttle cable. You can use your stock but you'll need to be creative.
i was reading your Q&A off your youtube page. i posted below.
How pleased were you with the quality/fitment of the OBX iTB's? I was unable to make out what you did if anything for IACV and FPR on your car, any comments? Seems to idle nicely. - jonny042
The fitment wasn't perfect. But that's to be expected from OBX. LOL. The hole on the cast manifold was not space/drill correctly. I had to use the dremel to to fix that. It wasn't a big issue.
I did took apart the whole thing to inspect it. All gasket are there, no missing nuts or bolts and no crossed thread. 1 of the crush washer on the fuel rail was cut unevenly, so fuel was shooting everywhere on the first fuel prime. - KaibaTuning
I completely remove the IACV. It's not need for my set up. Beside it ran better without it. I had to custom a plate to mount it. As for the FPR. I'm using a brand call "Vision". Preasure is at 48-52psi. It idle nicely because I'm using a syncrometer. It measure the amount air that enter each runner. Each runner have a adjustable idle screw like you would find on your stock throttle body. - KaibaTuning
@ 1:06 right next to my thumb is where the idle screw is at. I had to trim(dremel) that so it's easily accessible.
Btw, those are not the original velocity stack. I decide to use those so I can fit metal mesh screen behind it. - KaibaTuning
Ah very nice what thotle bodies does it come with? Are they are off a specific motorcycle I assume?
Also if it comes with a tps why not just scale it in ectune or any program?
The Great Weldini
91 civic
Discussion Starter #23
scroll down and you can see the adapter i bought, too. and speaking with Gil from Circuit Hero he stated there's only 10 adapters left once they're gone he's not making anymore.
Everything
The ITB are a replica of Toda A-Sport. It basically from the Toyota Levin/Trueno AE101/AE111 4AGE 20V.
As far as I know. The OBX D series ITB does not include the TPS adapter and/or water coolant fitting. You can order the adapter from circuithero.com and use the factory Honda TPS and calibrate it to spec.
The Great Weldini
91 civic
Discussion Starter #25
kaiba is right it doesn't include it. i'm going to use a D16y7/8 coolant nipple cause i can slip it snug tight. but again i have to do a little fabbing to do this.
The Great Weldini
91 civic
Discussion Starter #27
cool i will order it right now but look what came in the mail just afew minutes ago...
Circuit Hero TPS adpater
The Great Weldini
91 civic
Discussion Starter #28
Why not just run a 4age tps and scale the voltage?
Keep in mind I know nothing about the yota hardware and am ASSuming its electronic
The Great Weldini
91 civic
Discussion Starter #33
something i need to look into.
The Great Weldini
91 civic
Discussion Starter #37
Excellent work!
thanks you
Looking good Remo I would say no IACV keep up the good work with this!
thanks you, i need to do a little more reading.
this looks friggin awesome. any idea on the completion date?
great job and good patience.
thanks you and patience is a massive virture. lol.
as for completion date... thats a bit hard.
as GO-AUTOWORKS and rcautoworks can say i have a huge order list and asking for some custom parts. i am in the middle of testing for a nuclear power plant for a job. when i get the job my build might come to a halt, not cause of money but more of time. i am trying to buy as much parts that i can for when i'm home on the weekends i can be builing this motor. i just dropped off my short block at the machine shop to get the work i need done.
this will be my tedious build. i will doing a large amount of the work. a lot of measurments and trying for tight clearence to say the least.
this build is not for me to show ppl look what i can do, but more to prove to myself that it's possible to a N/A build what i've plan for years. since i already build a turbo build.(ducks motor was actually my build that i was going to do and i help him do) what makes it hard is that it's a DOHC ZC. it's getting harder to find parts and as ppl know i've been buying as much DOHC ZC parts as i can. so i will say lets see.
i will say i want thank afew ppl for pushing me into the direction i want/need to be.
thanks: Wil @ Exospeed, Greg @ GO-AUTOWORKS, rcautoworks and most of all kaiba: dude you've been a huge quantum leap forword and a massive help on this thread and helping me answer alot of question and more question to come.
The Great Weldini
91 civic
Discussion Starter #38
The Great Weldini
91 civic
Discussion Starter #40
21 - 40 of 79 Posts
