1 - 12 of 12 Posts
The Great Weldini
91 civic
so i hope this helps cause, don't get me wrong i just tired fishing thru massive threads and old links trying to find these specs. so i wrote it all down i thought these are some of the important i'm always looking for. if i forgot something please post it or if the specs aren't right on the ball.
i want to first state theres alot of tq numbers i didn't add cause well i feel a good snug to those bolts and nuts would be fine.. com'on if you need a tq wrench for 10lbs tq. i think you need to stop and go sew a quilt.
CAMSHAFT GEAR BOLT - 27lbs tq
VALVE LASH -
int. 0.005"-0.007"(0.13mm-0.17mm)
ext. 0.006"-0.008"(0.15mm-0.19mm)
when you lash your valves you need to turn your engine and make sure the cylinder you're lashing its at TDC of the it's cycle. the order you lash is 1-3-4-2. as you turn your crank 180* your cam should move only 90*.(i hope i explian that correct)
HEAD STUD -
1st step 2nd step
22lbs tq 48lbs tq
CRANK BOLT - 120lbs tq
FLYWHEEL BOLTS - 89lbs tq
PRESSURE PLATE BOLTS - 19lbs tq
MAIN CAP BOLTS -
1st step 2nd step
18lbs tq 47lbs tq
PISTONS GAPS
Top compression ring - 0.15mm-0.30mm(0.006"-0.012")
2nd compression ring - 0.30mm - 0.45mm(0.012"-0.018")
Oil ring - 0.20mm-0.60mm(0.008"-0.028)
PISTON RING TO GROOVE
Top ring - 0.030mm-0.060mm(0.001"-0.002")
2nd ring - 0.030mm-0.055mm(0.001"-0.002")
Oil ring - n/a
well on this part i borrowed this pic from Endyn and fixed it cause the original was a bit confusing to me so i tryed to make it simple. here's the original link.
http://www.theoldone.com/articles/engine_tips/piston_facts/pistonfacts.htm
when installing pistons the arrow on top of pistons must face towards the timing belt.
PISTON RING CLOCKING
CONNECTING ROD BOLTS -24lbs tq
CONNECTING ROD BEARING CLEARENCE - 0.02mm-0.038mm(0.008"-0.015")
CONNECTING ROD END PLAY - 0.15mm-0.30mm(0.006"-0.012")
MAIN BEARING CLEARENCE - #1 & #5 - 0.018mm-0.036mm(0.0007"-0.0014)
#2 & #4 - 0.024mm-0.0042mm(0.001"-0.0017")
#3 - 0.030mm-0.048mm(0.001"-0.0019")
CRANKSHAFT END PLAY - 0.10mm-0.35(0.004"-0.014")
well i really did this for me cause i'm rebuilding my ZC again so incase if i have to rebuild it again. lol.
1988 Honda CRX
Ring end gap depends a bit on where the grove is in the piston and ring material. Top ring is normally more gap than second.
Rod bearing clearance
0.02mm = 0.0008" to 0.038mm = 0.0015"
Crank end float
0.10mm = 0.004" to 0.35mm = 0.014"
This should be expanded and should have a sticky
The Great Weldini
91 civic
Discussion Starter · #4 · (Edited)
Crank end float
if you look they're both are on it...
your crank pulley is gonna fall off @ 89.
yeah changed it to 120lbs tq that what i was told on thezcr. thats why i kept getting piss cause i had to keep going thru a shit load of service manuals. from civic and integra. to make sure everything was fine. i will say this the crx si/civic si/dohc zc have about the same numbers. and when it dips into the 5th gen civic again it changes ever so slight..
1988 Honda CRX
They are both on there but you got your conversions to imperial wrong, some where a misplaced decimal place but some were plain wrong.
Edit
OK I see they are fixed now
The Great Weldini
91 civic
Discussion Starter · #7 ·
bottom end of ZC should have the same number as the D16A6........because it is!
yes it is bone..
They are both on there but you got your conversions to imperial wrong, some where a misplaced decimal place bur some were plain wrong.
yes you are correct. swaping the decimal...
The Great Weldini
91 civic
Discussion Starter · #8 ·
i do want to add patprimmer that was my problem i was getting screwed up with all the different specs old dead links and what nots. but i fell this should help in some senes.
The Great Weldini
91 civic
Discussion Starter · #10 ·
lol.. i overlooked that one fixed too..
Reactions: stinksause
95 CX Hatch
Bumping this dinosaur thread. Cam cap torque 9ftlbs? 108inch lbs. Sure...I'll go with that.
1 - 12 of 12 Posts
