1 - 6 of 6 Posts
honda all the way
i recently posted about motor mounts for a 1996 civic ex. i got no answers, i have a jdm d15b its going in a 1996 civic ex. what mounts do i buy teh mounts for a 96 civic or 92-95 civic....can anyone help me
it depends on the chassis you got the engine from. if the engine is a 92-95 d15b, you will use 96-00 main mounts and you need to swap the cast mount that comes right off the block to the one from your y-series. if the d15b is from a 96+, then you just use the 96-00 mounts, nothing else is needed or needs to be swapped.
referring to part number 9 or 10 or 11, depending on the chassis and engine combo.
to make it really really simple....
use all your OEM mounts including the bracket that comes off the block behind the timing covers. cool? :bigok:
1 - 6 of 6 Posts
