1 - 14 of 14 Posts
Was doing a valve cover gasket job just now, and i accidently tighten the bolt too tight and the bolt snap, the long one that goes furthers away from the hood. One of them snapped at the bottom end of the bolt and now i have 4 screws instead of 5 to the valve cover, i noticed when i removed one of the bolt it was very noisy and a bit oil spitting out.
im freaking out,,
will it leak?
can i just glue it back and let it leak forever if it got a leak?
it will leak. will it be enough to worry about?
how far down did you snap it?
meh. small drill bit down the center and an easy out will probably get it done.
'93 / '95 Del Sol Si - '95 DX Coupe - '98 Civic Hatch - '00 Accord EX F23 Manual
Which head is this? Non Vtec? A6? B7? Or Vtec? Z6, Y8, etc.?
It will leak...but if you use some gasket sealer around that area, you can get by until you are able to remove the rest of the bolt like slo_eg8 said.
Its the Z8 head, but should i drill with a left handed one?
For some reason, I couldn't see the pic the first time around.
Yeah, you can buy the kits at parts stores to remove them. They sell different sizes for different size bolts. They are also pretty cheap because they're usually for one-time use. I have the feeling that is going to be your best bet.
Left hand drill bit.......
And for the next time, grab the 1/4" ratchet with 6" extension and 10mm socket, place it between your middle finger and ring finger, like the T bar setup. 108 in/lbs or 9 ft/lbs is hard to achieve with that low leverage grip.
Discussion Starter · #9 ·
Got it out today. I couldnt drill it because the bolt snapped in an angel. So i drilled a bit at the side and used a screwdriver and hammer. Small damage around the area but i got it out and the threads remained undamaged so. I will update if there is some leak upcoming week/s
Congrats on gettin that sucker removed! I had the same break when changin my VC gasket n tune up a cpl months ago. Super frustrating! I was able to use 5/32 drill bit and 1/8 extractor, worked flawlessly. Fingers crossed for you, no leaks!
If all else fails and your afraid of leaking, clean and prep both surfaces and put a thin layer of adhesive rtv on both sides of the gasket. press it down and let it cure. You'd be amazed how well that crap holds
Discussion Starter · #13 ·
Hello back with an update, it doesn't leak from the valve cover. i have driven alot of miles ( kms ) like 2 full tanks which arounds up to 800km range per full tank. so thanks everyone with their help! i'll keep them noted
Common problem when not following torque specs, do like SLO suggests Cover area to keep debris from entering head when drillOmg small hole carefully down center
1 - 14 of 14 Posts
