1 - 20 of 20 Posts
as the title,
i found smoke from bottom end ,lot of smoke when my engine running and its oily
when i try to put my hand to that area..i found my hand full of oil
is it about pcv valve ?
how come will be if i keep that condition,can i fix it ?
many thanks
I would check for your oil filter leaking oil onto your exhaust down pipe
nope, i have checked the filter, and no leak from there,
because when i try put my hand, i feel theres gas/smoke burst out to my palm,from block
not from exhaust/header
all i know theres hose that connect that bottom block with intake manifold,near the left runner
d16A6 / ZC sohc block with mini me z6 head
are there ny effect of this leak to overall performance ?
blowby lol..
with or without any problems with the pcv box.. if it started to smoke recently? it would smoke even if the pcv box was fine..
try running the car at idle.. as u said it smokes from behind the manifold/below..
remove ur dipstick and check.. if it smokes? then its the engine
blowby lol..
tried running at idle and smoke keep appear from rear engine below manifold
checked dipstick too, theres no smoke out from there
and theres no leak from head part and head gasket
yEaH tHaT gUy!!!
check the oil pressure sensor. post a picture of what you see. so we know what your looking at.
i have identified exactly wheres the smoke blow up from
that smoke blow up from the black box that PCV valve connected on the block
my mechanics didnt connect the hose from pcv valve to that black box, so the smoke blow up from there to atmosphere..
im curious , are there any problem /effect to performance of that beside emission ?
is the pcv hose hooked up to the little black breather box?
damn, I hate to say I told you so, buuuutttt.......lol Glad you found the prob, hook that shit back up...
Discussion Starter #16
yeah found the trouble..:)
are there any problem /effect to performance of that beside emission ? if we keep opened that box
Discussion Starter #18
nope, im with NA setup
but in my case , the inlet on intake manifold plenum was used by something like compressor that help if i use A/C, because if i dont use that,rpm will drop when i switch on A/C because of vacum matter affected by high duration cam
so i cann't plug the pcv hose to intake plenum side,thats why the black box opened
Discussion Starter #20
do you have emission laws where you live? if not, some guys just attach a little air breather to the end of the hose
there s emission law but not too strict in other word no one care about that until this day
so i think i dont have problem with that.. o ic so i can put a little air breather
are there any effect to engine performance ? maybe dropping some hp ?if i keep that open
1 - 20 of 20 Posts
