1 - 6 of 6 Posts
M
I have a 1989 civic hatch gutted and fitted with the zc sohc and a 5 speed 89 crx si tranny. my problem lies within the oil chech/fill bolt. mine is stuck and stripped out. I have tried penitrating oil......and everything I know. has anyone heard of this happening? or possibilily have a solution? thanks
you can SLOWLY fill the tranny thru the vent hose........
on 92+ you just pull the VSS unit, very simple to fill.
M
I installed the engine and tranny myself but I not sure which vent-hose you are talking about. The only hose/cable(non-electrical) I can remember is the speedometer cable.....can I fill the tranny from this hole? Mine is pre-vss.....the numbers on the front are "L3 - 1360240" any help offered are greatly thanked by my tranny and myself.
:stupid:
sears has this new socket that has like razor teeth it digs into the bolt and takesit out and for amazingly low price of 10.99 plus tax
M
other than uninstalling aLOT of suspension there is no room to fit the socket. my $ is limited and i really cannot afford to get my car realigned...is there a way to weld a nut to the end of this bolt so i can have good teeth to work with?
1 - 6 of 6 Posts
