wg fire ring valve seat in place facing the right way?
a faulty wg will usually over boost.
Don't have anything to test compression but it shouldn't be the issue.Do compression check, verify your valve lash is CORRECTLY done, aka, not too tight and holding valves open.
Go slightly loose on exhaust valve lash, go middle for intake.
Then make sure there are zero exhaust leaks.
I personally would be looking for a spare head to do some valve love and porting on. nothing like a fresh valve lapping and some intake and exhaust porting to help things move along!
Car is not tuned, but this is why Im trying to get it working properly before going to the tuner.Did you get the car tuned? If not, and you just loaded a random starter map from the Hondata DB, you might not have provisions for boost?
A good tune will make a relatively large turbo perform pretty good, even on a smaller engine.
my dudes a psychic!
