1 - 20 of 21 Posts
wheres my money man!!
91 hatch
0 mile b1
brand new battery have tried 2
12.5 volts at battery/starter/and distroblock
when cranking drops to 9 volts
car runs fine when jumped it starts right up
all 4 gauge wire
grand is from tans to frame. and battery to rear bumper mount
car cranks slow by its self like a high comp v8
but odd i hooked the multi meter up so i could see numbers when i cranked it cranks a tiny faster and starts and sits at 12.8 volts
did you try a different starter???
All so try to use 2 gauge wire for starter and grounds and see if that helps...
why does it sound like that??? it sounds like its not running on all cylinders or you have no exhaust on it
I dont think its the wire it self. wire im using is good for 135 amps and 600 volts.
im thinking maybe grounds??
look in my build thread you can see how slow it turns over
I watched it all ready...has the timing???? I'm just giving you some ideas as to what it could,not saying that any one if them will work or not..
Certified O.G.
A Shitbox
Mine sounded like that when I had not enough grounds, add a few more, you never know :bigok:
missing o2 plugs
ya timing is on
any ideas are good ideas for sure man lol
thats what im thinkn to man.
Try and run a ground from the rear bumper mount to the tranny....
Discussion Starter #16
ive done 8 cars like this and never had a problem..i am using 2 gauge wire though...
i know hundreds of people who use 4 gauge wire.
just thought of these to.
from battery to the disto block is all normal battery wire. but from the distro to the starter its silver tinned wire. think that might cause it?
post pic of this disto block
try this,put the battery under the hood and hook up the starter with the factory wire if you have or use a new wire, then run a wire from the battery to the under hood fuse box...see if it still cranks slow...
1 - 20 of 21 Posts
