Ok heres my problem….. I have a 93 CIVIC SI D16Z6 I just replaced my transmission with another “d16z6 tranny” when I was bleeding the trans I noticed that the slave cylinder wasn’t tightening up and fluid was coming out of the cylinder and I noticed that the piston on the slave cylinder was out all of the way, then I took a closer look the slave cylinder is in a angle and it doesn’t match up looks to be to far away from the fork.
The fork and slave cylinder are both from my old transmission what do you guys think the problem is?
If fluid is coming out of your slave cylinder........replace it. It's cheap and not a bad idea to change it anyways since the consequence of not spending $20 will cost you a $60 tow bill.
you didn't line up the slave cylinder properly when reinstalling it, blew the plunger out.
replace slave and bleed system.
you have to make sure the piston/plunger end fits into the arm, if it comes OUT of the slave cylinder, replace it.
