1 - 2 of 2 Posts
i have a 1997 civic lx im looking to get some more air into it so i bought a skunk2 manifold an had wondered if anyone else has ran it and if there are things i need to know about it. is it just bolt and go after swapping stuff. i just want to do it the proper way and have good results. thanks in advance ~ nOOb Ivan
Make sure the skunk2 manifold accepts a D series throttlebody.
The d16y7 IACV is 3 wire and mounted on the throttlebody.
The other traditional plenum intakes have a 2 wire mounted on the back of the plenum.
If the Y7 throttle mounts to the Skunk2 manifold, you are okay.
If not, you will need to figure out a way to keep the ecu happy
1 - 2 of 2 Posts
