95 civic ex coupe
so i bought this throttle body last month, i like it alot, alot better throttle response alot better top end i like it :)
so here is pictures and my review
next to the stock tb
before i ported the intake manifold
after
I was racing someone the other night, my car threw a tps code and throttle was sticking almost halfway open i had to smash on the gas pedal to get it to return to idle and it did this many times...
i pulled the throttle body off and pulled the tps off to find this
wtf? how did that happen...whatever
i looked and the throttle body looks like that plate how it has a flat side, but they use that whimpy ass screw so i fixed it
just if you buy a skunk 2 throttle body, remove that little screw and put a washer on it before use
Its called Junk2 for a reason.
Sent from my DROID3 using AutoGuide.Com Free App
1971 VW Super Beetle
I hear you should also loctite the throttle plate screws. More than one person has apparently blow their motor from those little screws coming loose and having a field day in the motor.
95 civic ex coupe
yea yea yea i know man... i myself talk mad shit on skunk 2 products just because of my personal views of dynos between other certain manifolds and skunk 2's and the power output of other manifolds compared to skunk 2....
but i liked how the skunk 2 looked like i was oem looking thats what made me choose them over any others but yea i guess ill take my throttle body off one more time and loctite those screws because if that shit blows my motor skunk 2 wont replace it :(
wtf....now you all got me worried....
i also have the alpha 70mm been ok for about 500mi
94 Del Sol si
I had a skunk2 68mm pro series billet throttle body, and there was leftover machining whiskers in the IAC port.
