1 - 15 of 15 Posts
Stock D16z6 On 10psi With 16g Turbo.
What Size Charge Pipe?
What Size Downpipe?
What Size Exhaust Piping?
Just Need Some Opinions, thanx
yeah the motors stock i just want to atleast get close to 200whp, do you thing thats possible
95 ex coupe
200 is possible.
do a 3 inch exhaust and 2 1/2 charge piping.
remember. air can only flow as fast as the smallest pipe will let it so if you have 2 1/2 inch DP and 3in catback. its no diff then having a 2 1/2in catback. so get it all 3inch for the most gain
Lifetime Awesome Member
'89 CRX HF
2.5" charge pipes
3" DP if it will fit
3" exhaust even if the DP isnt
...2 1/2 inch DP and 3in catback. its no diff then having a 2 1/2in catback
not true. 3" exhaust will still make more power than 2.5" exhaust even with a 2.5" DP. the exhaust still has to make bends and over the rear LCA, and the smaller exhaust will hinder performance
95 ex coupe
2.5" charge pipes
ahh forgot about the bends.
also get mandrel bent exhaust. if a exhaust shop does it it can have the ripples in the bends which makes the airflow not as smooth.
thanks for correcting my ryan.
95 ex coupe
2.5 all around on that setup
and your reasoning?
bigger exhaust will help spool faster.
not that it will lag at all but the faster the better.
95 ex coupe
thats what i ran and i made 300hp and 250 ftlbs plus its a little quieter
and you dont think you could of made anymore power with a bigger exhaust?
kinda wierd how your numbers are a perfect 300hp and 250ftlbs.
4dr ls
well at 15 psi i made 294.8 and 243.7 and i went to 18 psi so i can claim its close enough and it may have made more but i like having some back pressure for startup and engine braking and on a daily driver 2.5 in is plenty big and it will help with drivability
yeah the exhaust i have now it 2-3/4 mandrel bent but i think im going to up grade
im gonna go with a 3in mandrel bent exhaust with vibrant muffler, should i delete the cat, and resonator, or keep one, just need opinion
What Size Downpipe?
2" hot side, 2.5" cold side
biggest you can fit, keeping ac? 2.5 no ac do a 3"
3" but if your on a budget easier to find a 2.5
Discussion Starter #15 (Edited)
Yeah Im Not Running A/C. Ive Decided On 2.5 Charge Pipe, And Im Gunna Go 3" On The Exhaust With A Vibrant Muffler, My Dad Can Get Me 3" Mandrel Bent All The Way Back For A CRX For 75$, But Yeah I Got A Few?'s
Resonator/Cat? Should I Delete Both Or Just One.?
Opinions On If Its Possible To Reach 200whp
1 - 15 of 15 Posts
