1 - 19 of 19 Posts
anyone know the size of the skunk2 intake manifold throttle body hole? i want to be able to buy a new throttle body that is the same size as the opening in the manifold, so i wont have to portmatch. also does anyone know how big the b16 and b18 throttle bodies are and if they will fit on a d16z6?
G
b18c1-60
b18c5-62
b18a-58
b18b-60
b16a SiR-58
b16a Sir2 / b16a2 / b16a3-60
They will fit the Z6 intake manifold
Don't know anything about the Skunk2, Email them or your nearest Skunk2 dealer.
· i am the walrus.
Civic hatch
sqmark said:
b18c1-60
b18c5-62
b18a-58
b18b-60
b16a SiR-58
Good info.. I have B16 throttle body I was going to use on my y8 mani.. good to know.
how do you like the Skunk2 IM Jaker? i just bought one and is coming in soon, can you feel a good amount of power from the IM?[/quote]
G
just in case anyone is interested i found that kingmotorsports.com will bore out your throttle body 4mm larger for 150.00 - i dont know if thats a really good price or not but cheaper than buying one already bored out no doubt.
I bolted the Skunk2 onto a D15B1, and the motor doesn't have anything internal done to it yet. I'm on my way there soon enough. I certainly didn't lose any power, but I can't say for sure I gained any. The top end seems to have a little more oomph. I used to stop making any power at about 6,500-6,600. Now it keeps pulling a bit longer. But remember, we're talking the wimpy D15B1 cam, and, what, about 9.2:1 compression.
The motor has the Skunk2 IM, T1R 4-2-1 header, Hondata S200, 2 1/2" mandrel exhaust, 58mm TB, and 3" cold air intake. Next I'll be bolting on a head that has been shaved .050", and running with 1 layer of a D16Y8 HG, so compression should jump up to about 11.5:1. At the same time, I'm throwing in a Colt Cams D16A6 regrind. We'll see where that gets me.
Next, to put good use to all these high end parts, I'll be building a D16A6 block with a D16Z6 head, and lots done to the inside.
So to answer your question, I believe I got some gains from the Skunk2 IM, but don't have any hard facts to back it up. It however was a bitch to install. The firewall clearance is "minimal" to say the least. I had to ensure the IAC was bolted on before installing the IM, as there was not room to do it afterwards. I had to cut the head of the bottom IAC bolt down to half its original height. I had to give the firewall a few good whacks with the BFH to gain the required clearance. Keep in mind that I am also running the Hondata IM gasket, but that only accounts for about 3/32" less clearance.
The only other problem I had, which will affect any of you planning on using this IM was to do with that coolant hose neck. The clearance between the neck and the runner for port #4 is so small, that the hose would not squeeze through the gap. I had to cut the outside diameter of the hose down in half for it to slide in. I also had to use a regular screw type hose clamp, as the Honda one is thicker steel, and would not fit.
Discussion Starter · #9 ·
so will i have the same problems u had installing the IM? i have the d16z and isnt the manifold made for that motor, so would it be easier to install on the d16z?
You will have the same problems with firewall clearance if you are putting this in an EF. You will have the coolant hose problems no matter which car you install it into.
Don't get me wrong. The manifold fits with the above mentioned mods. However, it is not a straight forward bolt in.
G
does the stock 89 crx fuel rail work on the manifold and what do you do about the MAP sensor when you put on a newer b-series t-body isnt it different. i am using a crx ecu.
You'll need a fuel rail from a 92-95 Civic. The map sensor thing is simple. If you are using the TB mounted MAP, just extend the wires that attach to the CRX MAP on the firewall, so they'll reach the TB mounted MAP.
isnt those coolent lines mostly for the cold startup, for the TB, i thought you dont need those things, just that the car idles higher while warmning up. :?:
Cheetah said:
the SKunk2 intake manifold is 64mm opening.
I emailed skunk2 and they told me PLUS the guy selling them (in classifieds) says that
same here ! they ARE 64MM
G
well, the only way to find out for sure I guess would be for someone to send a letter to skunk2.
Maybe I had bad info told to me or maybe you have a bad mani. It would be nice to find out for sure.
HERES THE MAIL I GOT ! :
Thomas,
Thank you for your interest in Skunk2 Racing products. The intake manifold
and cams for the D16 are available now. The PN for the items are as follows.
SOHC Intake Manifold 307-05-0260 Retail $338.87
SOHC Satge I cams
305-05-0100
Retail $531.27
TB size the manifold will take is 64mm and up. If you go larger than 64mm,
it is suggested that your match port the intake to the TB.
Best Regards,
Tony Miyamoto
Account Executive
Group-A Autosports/Skunk2 Racing
2050 5th St. Norco, CA 92860 USA
PH. 909-808-9888 Ext. 200
FX. 909-808-9889
[email protected]
http://www.skunk2.com
1 - 19 of 19 Posts
