1 - 16 of 16 Posts
hi.. simple questions that would be quicker to ask you fellas instead of googling...
1-Turbo gasket, down pipe gasket, Exhaust Manifold gasket-- Shall i use Gasket Sealant??
2-Bolting Turbo manifold to block-- Arm strength criss-cross or Torque wrench-__ ? pounds
3- Intercooler piping is bent in some spots (rocks gravel etc) - Safe to straighten and adjust with needle nose pliers?
thanks fellas for any info
1. no need for sealant
2. use the german way, goodntight
3. how bad are the "bent" parts of the charge piping?
ej8
^x2
and pliers left marks on the pipes so it could cause a leak at the coupler. Pix would help better tho. and small dents shouldnt hurt flow that bad
that aint going to hurt shit, leave it alone
yessir :-D now on to my Fuel injector posts:-D
BTW Thanks fellas
slok uve been quite helpful since ive joined the .org
thanks ^
BTW Thanks fellas
thanks ^
no problem, its why im here.
and most of the time if i think its a stupid question or something been covered before a million times, i wont even respond lol.
Are there any cons to adding that high temp silicone on the ex. manifold gasket? I have been doing this out of habit for years. But I will stop today if there are reasons not to.
yes the sealant destroys o2 sensors and they stop working correctly.
1988 Honda CRX
You can get O2 sensor friendly silicon sealant, but it is not necessary unless you have to use a damaged gasket for some reason. With good gaskets and proper practices, sealants are just a waste and even as Dan says, a potential problem.
They also make it harder to reuse a gasket that has been installed with them if you have to do emergency repairs.
1988 Honda CRX
EJ6
I don't use any gaskets on the turbo or after it... works fine for me
1 - 16 of 16 Posts
