1 - 6 of 6 Posts
2000 4dr civic dx
I'm trying to get my fender out but, I need to remove my side skirts
first,to remove the bottom bolt. At the moment I am having trouble
taking it out those clips holding it in place from underneath the car.
My car is an EJ6 4 door. Thanks guys!
Red EG
k there are two things holding that skirt on.
those screw-pin plastic things underneath it, and some white slide clips inside it. the screw pin plastic things are almost impossible to save, so just get a bag of new ones. once all the screw pins are out, try sliding the skirt along the car, and the inner plastic clips should release. take notes while you do it cause puttin it back on is a bit trickier.
2000 4dr civic dx
just unscrewing them, they already started to tear.
these pins are really hard to take out, I guess i'll just break them.
I'm gonna try your method now.
I'll post again if I still need help. thanks!
just try tapping i think from the back to front you dont have to slam it just tap itloose usually there is alot of dirt built up and its holding the side skirt to the car
2000 4dr civic dx
Thanks I already got it off.
For future reference, after the screws are removed,
just slide the side skirts from the back door towards
the front door.
Takes a bit of effort because it's hooked on 4 pins.
Just in case anyone else wanted to know...
1 - 6 of 6 Posts
