1 - 3 of 3 Posts
I am looking at a tranny that the seller claims is from a 89 crx si the #s are L3-1319317 so if it is infact a 89 it would have 20 splines correct I searched and read allot in this tranny section didn't find or maybee didn't understand the limitations with some different years bearing sizes and such. If it is an 89 what clutches /flywheel /pressure plate /LSD combinations would I have I want to run a stage 3 or so cluth and light flywheel. Currently I have a JDM D15B with the stock STD 4 speed just wondering if there is any problems I would run into.
crx and ford ranger
you will have to get the clutch kit for the 89 tranny off ebay or whatnot
flywheel you need one for a 88-89 and LSD im not sure almost can guartee there is a way for that also other then that you shoiuld be straight
1 - 3 of 3 Posts
