I just acquired an 89 d16a6 L3 trans out of a crx si. I plan on swapping it into my 90 dx hatch with a d15b2. Can I just use exedy kit designed for the stock Dx or do I need to piece together a clutch kit for my setup?
:TU:You can use a clutch setup for any 90-00 Civic because the '89 trans has the same spline count as the 90-91.
An '89 clutch won't work unless you swap to an 88-89 flywheel, which would be a waste of time.
