1 - 6 of 6 Posts
i just purchaced a 95 eg coupe with a d16z6 w/240k on it...it has a nasty rod knock..people are telling me to rebuild it rather than replacing it...what exactly do i need...? could there be any damage to the motor that cant be fixed? i saw a complete rebuild kit on ebay ? is that all i need..would like some input...im kinda new at this...
thanks for the help.
See above...
First, strip it all down to see what exactly has happened. Second, if it is indeed a spun bearing a new crank might be in order. Third, the new crank needs to be measured and matched with appropriate bearings. Fourth, while apart replace ALL worn seals/gaskets/belts. Fifth, SEARCH.
FF Misfit
Accord
What are your plans for the car?
1 - 6 of 6 Posts
