ok well my dads an old hot rodder and back in the day u could do certan things that u cant do to hondas, ie cutting teeth on syncrohs to make the MT clutchless once rolling. well he asked me to post this question on here for transex, bense, or any other d-series.org god.
Q1: can u shim the spring inside the oil pump housing to rase oil pressure?
Q2: if it will raise oil pressure, wi'll the raised oil pressure cause any problems with lubrication, or create any other problem?
Q3: will the raised oil pressure( if it does work) effect vtec in any way
thanks u. it might be a dumb question but this is the only place i can go to ask questions and not get laughed at
Daniel
Daniel
