hi guys. i'm having this problem, which started a few days ago. my shifter is getting stuck between second and third gear. it is not that i can't shift, but hell i gotta yank it. what could be? o-rings, bushings? any help is appreciated.
sorry man, and thanks. yes i did changed the tranny fluid, two months ago.be
patient
some
of
us
work
check your tranny fluid level, and when it was last changed, then ask again.
lol I couldn't resist, you posted something like 4 times.
hmmm, what tranny is it? Does it do this only upshifting or downshifting too?
silly importracer: most of the time it does it when i'm driving hard. sometimes when i'm just cruising around. it's not that it does it everyday, but it does it quite often. it's like one or two or three days is ok, but then -and without notice- it starts again for a couple of days.Everytime you shift from 2nd to 3rd or only when you're driving hard?
thanks green_hornet_96. concerning your question. no, it only happens when i'm shifting from second to third. 2nd to neutral is ok, same as 4th to 3rd.Reason I asked about the short shifter was because my cheapo $14 unit would bind like that. Tightening it down to get rid of the vibration and buzzing crushed the ball bearings and kept it from working right.
Does it ever shift hard shifting from 2nd to neutral, or from 4th to 3rd (hard going into 3rd)?
do you have any trouble shifting in to first
Yeah, rolling just a bit usually helps if you are on a hill too.Regarding getting into Reverse, I usually put into 1st and move ever so slightly and then it's cake to get into R.
