who cares what they're for. just post emI've got hondata ones...
How can you take away fuel in closed loop (when the o2 is triming the a/f ratio)? Because won't it just correct any adjustments to the map below full throttle ( or when the o2 isn't used). Is there a point where the 02 sensor is unable to adjust. Like if you increase so much that the o2 is unable to bring it back to 14.7.people wouldn't understand nor will I or Blundar be held responsilbe when something get fucked up.
Dave still wants to datalog mine, in his opinion it can't be right.
Pulled 10-15% fuel, added timing.....which is a good start.....then he found out I'm only running 30 psi under normal idle vacuum fuel pressure, 36 psi with the line off.
I would think that the O2 would show rich to the ecu and it would trim fuel off until it gets to the rich--> lean--> rich swing again.How can you take away fuel in closed loop (when the o2 is triming the a/f ratio)? Because won't it just correct any adjustments to the map below full throttle ( or when the o2 isn't used). Is there a point where the 02 sensor is unable to adjust. Like if you increase so much that the o2 is unable to bring it back to 14.7.
Our ecu can adjust fuel up to 20%.How can you take away fuel in closed loop (when the o2 is triming the a/f ratio)? Because won't it just correct any adjustments to the map below full throttle ( or when the o2 isn't used). Is there a point where the 02 sensor is unable to adjust. Like if you increase so much that the o2 is unable to bring it back to 14.7.
