1 - 2 of 2 Posts
Hey guys,
First post here, and I need some help.
I have a 91 Civic HB that is turned into a oval track race car. Anyways when the previous owner turned it into a race car, it seems they cut out the service connector that you need to jump to set timing. Not under dash, not in engine bay. Anybody have any idea how I can set the ignition timing on the car? Any help is appreciated!
Thanks in advance!
Kyle
Adia's Daddy
2004 Honda Element
You will need to get ahold of a wiring schematic from a Honda manual in order to see what wires you neet to short on the ECM/PCM.
If not, you will never be able to set base timing because the computer will constantly re-adjust on the fly to compensate for the changes you make manually.
1 - 2 of 2 Posts
