1 - 14 of 14 Posts
What should i set the timing to?
d15b7/y8 head. y8 cam gear, I/H/E.
In all the mini-me write ups, it never tells you what to set it to, im sure the bump in compression, etc, changes the timing. So what should i set it to? Or whats a good start?
Eh, sort of. My old dizzy just took a shit on me. So i had to get a new one. Now its pinging like a bitch if i get on it at all.
Tunes are expensive=( lol
once i got the cam timing dialed in then i just set my ign to 16* btdc witha timing light and i dont ping at all. and with the y8 head on the 15 block and still using the y8 gear your cam timing is probably off
isnt it y8 head with y7 cam gear?
Use 88-95 cam gear, set timing to stock 16 BTDC.
the 16* btdc is for ignition timing and the y8 gear being 4.75* off is mechanical timing the mechanical timing needs to be right on to start with then adjustments made on a dyno to optain max performance in the desired rpm range. remember that every time a cam timing adjustment is made you need to reset ignition timing
:3dtard:I knew that. I fail. lol.
Ill prolly set it to 16 btdc, see how it reacts. if its ok, ill leave it there. If not, adjust from there. This motors only gonna be in for 6 more months, maybe...no point in chipping it, wasting money on getting a tune, etc, etc.
ive been running a b7/z6 with stock p28 for awhile and it has no detination it runs a touch rich but thats ok. after i got the cam timing set i set the ign and it runs great. but as transex said you need a 88-95 oem gear.
1 - 14 of 14 Posts
