1 - 6 of 6 Posts
00 civic dx cdm
i recently changed my water pump and am having trouble with timing... my timing is way too advanced... its like 2 inches away from 16+-2 BTDC. i checked with timing light today after resetting the crank and cam and putting back on the belt...
i did follow the procedure of manual... its so weird cause everything seems fine when i turn the crank so the pointer is at tdc, the camshaft is also at tdc... but when i run the engine and check with the timing light, it is so advanced that even when i turn the distributor to the max advance timing position it is still so advanced 2 inches away from the 3 marks....
but why the hell when i stop the engine and position the crankshaft to tdc mark then the camshaft ligns up perfectly with it... but when i run the engine it ignites way off... here are some pics of the crankshaft position which seems to be synched with camshaft when engine is not running. whats going on ?
Love the Civic
How did you remove slack from the timing belt?
Did you jump the service harness when setting the timing?
00 civic dx cdm
hi i removed slack by unbolting the adjusting bolt pulley and then i apply some force to make sure all the slack is gone... also i did use a short in the 2p service connector
by the way do you know what order is it for installing belt? manual says 1-oil pump, 2 adjust pulley, 3 water pump, 4 camshaft
but that doesnt make sense because all the slack will get to between cam and crank. i will do it again tomorrow
but i dont get why when the engine is off cam and crank line up (not perfectly but the marker on the crank puley is between 16 btdc and tdc. however when running timing light shows it is wayyyyyy off at least 2 inches before 16 btdc... and the belt seems ok like no slack or anything
Love the Civic
To remove slack you turn the motor over by hand 6-9 times, counter clockwise, and dont put force on the idler pulley, its not how it is designed.
When you set the crank pulley, set it off a bit so when the slack is removed it is dead on balls, being off .5 - 1 tooth down bellow is significant up top at the cam, or even at the harmonic balancer where it can show up as 2 or 3 degrees off, or more.
Never finishes (TWSS)
91 Civic SI hb/ 01 GSR
Well if you have everything lined up properly and the exaust side of the belt is even a bit snug you cant be off. You can only be off by a whole teeth if you have somthing miss alined when putting the belt on. The center to center of the teeth on the belt arnt going to change.
And yes you do have to roll the motor over a few times before tightening the tensioner. I left my car in 5th gear with pugs out and pushed it to turn the motor in the past
1 - 6 of 6 Posts
