self clutch install
675 Views 3 Replies 3 Participants Last post by  SpoolinSol
Ive had quite a bit of expirience in mechanics, but never done a clutch install before. Just posting to get some pointers or anything to look out for while doing a clutch install on my turbo eg. Also, tips on resurfacing the flywheel would be great. Thanks guys.
1 - 4 of 4 Posts
If you have a used OEM Flywheel I would definately get it resurfaced. Also a clutch install isnt hard.
Torque the flywheel down using this pattern.
.......1........
....3.....5....
....6.....4....
.......2........
Then put on the clutch disc and pressure plate. Not sure the specs for those but I am sure someone will tell you.
Then put the tranny on...
Torque the flywheel bolts down to 87lbs I believe. Do the pressure plate the same but at 18lbs. This should help some.
get a haynes manual and i'm sure you will be fine, good luck
1 - 4 of 4 Posts
