361 - 380 of 497 Posts
Thats perfect, the Monroe like worn out old stock springs, you will likely be replacing them often, but should be able to find them lifetime warranty
Sloppy Jalopy
Discussion Starter · #362 ·
canada sucks
crappytyre 140$+change each not in stock will never be.
garage close by that deals them 145$ each
neither offer a warranty here...
canada sucks
check out partsavatar.ca KYBs are 76 bucks each, and free shipping too!
sigh ..
well ,granny broke her hip.
What'd u do to poor granny now? You know she can't boogie like back in the day!
Sloppy Jalopy
Discussion Starter · #371 ·
tell me about it.and I thought I was going easy on her ...
Sloppy Jalopy
Discussion Starter · #372 ·
To the dildo that packed this a t the washington rockauto warehouse ,fukin blow mee.
and the delivery driver that thought it was a seat cushion ,stick it up yur jackass ,twink..
The power they must feel within.
139032
that's what I get for splurging on the made in japan.
send the photo to rockauto and ask "wtf"
love the plastigauge. was someone's tolerances too tight?
  • Haha
Reactions: robgoof
Sloppy Jalopy
Discussion Starter · #376 ·
it just wouldn't fit..
Damnit Ricky Bobby! See what happens when you get that Amazon driver who's watched Talladega Nights one too many times?
That sucks dude, hopefully they get it resolved and get you new sets soon.
nah he just had hemorrhoids and the plugs were soothing to sit on..
Wow scrambled spark plugs and such.............sheesh
yeah but not tasty at all..
Sloppy Jalopy
Discussion Starter · #378 · (Edited)
took the time to take granny out of Mr. and since it was so hot and sweaty outside I decided to strip her down right on the lawn..
head gasket looked great,
pistons 1 and 2 had some carbon blasted off 3 and 4 looked fine.
139367
so the dirty knockers was on rod #2 the others looked "ok" but the top shell on 4 was losing hold..
139368
139370
yup another fuck'd b7 crank ,maybe I will replace the rock I've been kicking with this .
at least the rods didn't change color.
Sloppy Jalopy
Discussion Starter · #380 · (Edited)
even before ol' gran was declared ded I started on my next 50/50 garanteed build ,,,50 feet or 50 seconds whichever comes first but who are we kidding we all know I'll come first..
y7 block crank and head ..will need a name.
some nasty holes
139385
ended up sinking the plug a little deeper
also sanded 0.015 off the 0.075 thick bypass bolt washer
139386
the rods I'm using are like 4mm wider than the last h-beams I notched for ,already had to go back once after cleaning it all spotless ..
139387
this will probably end up hurting my butt but I did it anyway.
139388
another nasty hole gah damn! chamfer..
139389
also did a welfie journal polish ..800-2000 cockwise
this is how loose or tight, what ever you want to call it each hole is, first checked with a finger then plastigauge.
139390
