1 - 10 of 10 Posts
crx and ford ranger
what safe number of boost to run on stock mini-me with a MX-6 small turbo im on 7 now anyway 10 is possable?
pretty sure you can do 10psi but a tune should be done of course
crx and ford ranger
yea i pretty much figuered that much i need one anyways. fmu is doing pretty well and i am about to finally get a damn walbro 255 pump so that would help out nicely then its to the shop down here to get tuned
1991 crx dx
ten is do able just need a good tune
You'll have no problem hitting 10psi. Just make sure you tune it properly. I've seen that turbo can hit 22psi on an A6.
crx and ford ranger
Discussion Starter · #9 ·
im getting a good tune anyone on here do crome there is noone around here that will even mess with it and i need a p28 and OBD-1 conversion harness for this aswell i dont really plan on going past 10 i think that should be a good number to stop at
If only you were closer to STL. We have a guy here that chips our ECUs for free with Crome. Rywire.com sells a OBD-0 to OBD-1 conversion harness for $199.99.
1 - 10 of 10 Posts
